-   -   Help! Can't remove manifolds (https://www.offshoreonly.com/forums/general-q/98228-help-cant-remove-manifolds.html)
CN24 03-13-2005 02:05 PM
Trying to remove the exhaust manifolds on a stock 454. All the heads on the bolts are completely rusted off, GONE! You would think the manifolds would slide right off but the studs must be rusted to the manifolds. Any suggestions how to get them off. I'm not trying to save the manifolds.
woody1 03-13-2005 02:22 PM
Re: Help! Can't remove manifolds
heat
puder 03-13-2005 03:23 PM
drill them out.
or if they are actually totally gone soak them woith wd40 and start smacking the manifolds with a mallet
Smitty 03-13-2005 03:24 PM
If you do not need to save them, then hit em hard on the sides with a hammer. They are made of cast iron and will either give way or crack. Keep going till you are done.
CN24 03-13-2005 03:25 PM
Originally Posted by woody1
heat
Tried
bowtie 03-13-2005 04:53 PM
Burn the heads of the bolts off with a torch. I've done it many times. Less than 30 minute you'll have both manifolds off.
CN24 03-13-2005 05:08 PM
YOUR NOT LISTENING! Just kidding, I appreciate all the input. The bolt heads are completely corroded off, there's nothing to burn. The manifolds must have rusted solid to the bolt stubs. Tried hammering off , just short of a sledge hammer, but I didn't want to damage the heads.
Comanche3Six 03-13-2005 05:46 PM
Grind every bolt head to make sure there is nothing left holding the manifold on. Strike it with a mallet.
R Addiction 03-13-2005 06:13 PM
Hose it down with WD-40 and hit that Mutha!!! Not being a smart Azz but you do have all of the bolts out right? Some of them may be rusted away so you can't even tell they're bolts!!
GET MEAN WITH IT!!!!!
R Addiction 03-13-2005 06:14 PM
Short of busting the bolts off in the heads I don't think you'll hurt them. If you do....then you get a new set of heads and have some work done to them, new cam.....you now upgrades :D
Chris Sunkin 03-13-2005 06:42 PM
I'm assuming the motor is out of the boat.....
Make sure there's absolutely nothing left of the head, then heat the bolt with a torch- for a long time until the bolt glows and starts to melt. At the same time, have someone in between the head and the bolt with a prybar. Start at the end. Heat the next one down, then the next. The pressure and the thermal cycling should make them pop loose.
If that doesn't work, torch 'em off or use a Milwaukee angle grinder with a 1/16" abrasive cutoff disk and cut them off.
JCPERF 03-13-2005 07:12 PM
Get another 454 :D
