-   -   Need A Good Prop!!!! (https://www.offshoreonly.com/forums/general-q/98235-need-good-prop.html)
CAPTAIN CHUCK 03-13-2005 03:55 PM
I Am Trying To Find Out What Would Be The Best Prop For A 1994 24' Baja Outlaw W/ A 454 Mag......i Want Something That Will Give Me A Better Hole Shot. I Know The Prop I Have Now Is A 24...but I Do Not Know What Brand. Thanks For Any Help.
Griff 03-13-2005 08:01 PM
Re: Need A Good Prop!!!!
A Bravo 1 prop will greatly improve hole shot and cruise speed on a 24 outlaw. It will also cost you about 3mph on the top end.
The fastest prop is a labbed 23" Mirage plus. you would need to run a 22" Bravo 1 Prop.
You could also try one Houston Props Accelerator designs. They are supposed to have a better holeshot, cruise speed and top end than Mirage plus.
BTW, I had a 93' 24 Outlaw with 454 mag.
CAPTAIN CHUCK 03-14-2005 02:19 AM
Thanks Griff...i Am Going To Give Houston Props A Call. Do You Have A Ballpark Figure On Any Prices? Take Care Bro'.
throttleup 03-14-2005 08:10 AM
What are your goals? This will help you to narrow in a propeller.
The Bravo I 4B works very well on your boat. The performance and handling are much improved over the Mirage Plus, although the Mirage Plus will be about 1.5 knots faster than the 4B.
Julie
Badtoon 03-14-2005 09:36 AM
i HAVE A BOX STOCK 23P MIRAGE PLUS FOR $275.00 AND I'LL SHIP IT TO JULIE IF THAT'S THE PROP YOU DECIDE TO GO WITH THEN THEY CAD DIAL YOU I.
Holy Smokes 03-14-2005 12:43 PM
I have some props you might be interested in.
It's a Chad Hill custom 3-blade 24P x 14" diameter. The diameter is 3/8" smaller than a standard Mirage Plus that lets it rev a little higher and it has some cup added to the blades to help bite while coming up on plane. Prop is in "like new" condition and comes with hub. $250 shipped to your door. Let me know if your interested.
Or, I also have a standard 23P Mirage (non Plus). Like new, $225 shipped to your door.
CAPTAIN CHUCK 03-14-2005 12:46 PM
Julie
I want a prop that will help me plane out faster without losing any top end. Will the mirage help on hole shot as well as on top end? i am runnig about 57 mph on the 24 pitch 3b i have now. I want more speed!!!!! :eek:
Griff 03-14-2005 03:00 PM
Might help, might not. We have no way of knowing how slow you are at getting on plane. Also don't know exactly what prop you you have now. Most all props are a comprimise at one point or another. I can say that 57mph is 2-3mph slower than a 23" Mirage Plus with your power. Are you trimming it all the way up till you stop gaining mph??? 24 Outlaws like a lot of trim. Use trailer up button for a little more if you have to.
I'm guessing your best comprimise will be a labbed Bravo 1 4 blade. It will get on plane much faster and will actually probably be faster than your current prop.
What is your current wot rpm????
That engine is best run right at 5000rpms.
Sydwayz 03-14-2005 03:46 PM
Remember, the more you talk about hole-shot the more you are drifting the line of IF / WHEN your drive breaks on you, from IF toward WHEN.
Prop your boat best for your top end. Leave it there. Pamper your throttle. Treat it like there is an egg on the back side of it. It will pay off in the long run.
Griff 03-14-2005 04:14 PM
In his defense, 24 Outlaws are WAY slow to get on plane. Don't hammer it all at once, but with 4 people in the boat and full tank, and a Mirage Plus you've pretty much got to go to WOT to get the boat to plane over.
My pantera will plane out twice as fast with less bow rise and less throttle than my 24 OL did.
