-   -   I need a hand with a sender on a Eliminator (https://www.offshoreonly.com/forums/general-q/98393-i-need-hand-sender-eliminator.html)
hpy540 03-15-2005 03:05 PM
I started putting my wiring harness on the 540 today with expectations of dropping it in this weekend. Yes i know i said i was going to drop it in last weekend but hey things got pushed back(my pushrods didn't show up). I now find out that i do not have a oil pressure sender on the old power. I called Eliminator to buy one and their parts guy is on vacation till next week some time. Can NE1 tell me what PN sender i should put on this thing. I would imagine it is a standard analog sender that i could pick up at NAPA or something. It is a 236 eagle and it had a 454 mag in it. The old power was froze broke and did not have a sender, just a hole where it was. I will check and post the pressure range a little later. I checked Bam and i cannot find a mec sender diagram. Eliminator has their own gages( WHO MAKES THEM? MAYBE GAFFRIG). If any one has any experience with eliminators or what sender i should use, let me know.
thanx
Mark
WETTE VETTE 03-15-2005 03:28 PM
Re: I need a hand with a sender on a Eliminator
The guages could be Gaffrig or maybe Faria? Is it an 80 PSI guage? Just make sure the sender matches the guage. I once ran a 0-100 PSI guage with the standard 0-80 PSI sender and the pressure read way high. Check the Rex or CP website or give Fred a call at Trick Marine. Auto store senders might work, but I would feel more comfortable getting the exact one for oil pressure.
Craig
lightspeed 03-15-2005 04:02 PM
If You Have West Marine Around You They Would Have It Teleflex Makes them Just make Sure Sender matchs Gauge. 80 lb gauge 80 Sender
HPJunkie 03-15-2005 05:34 PM
Hpy 540, I can't wait to hear the results. Greg
hpy540 03-15-2005 06:33 PM
Hey Greg, when i get this whole scenario finished i wouldn't mind a trip to the Rockford area. I have two properties i am developing this summer and a additional spec for a client but i hope i can play with my new toy a little. would ya care to show me around the northern IL lakes?
tomtbone1993 03-15-2005 06:40 PM
check with TRICK MARINE, i ordered mine today
HPJunkie 03-16-2005 07:11 AM
Mark no problem. Maybe we can get a couple hot boats out at the same time? Ever been to Madison wis? Good spot. Mississippi river?http://www.fullmooninjune.info/pages/2/index.htm We are going on the 17,18,19 of June your welcome to go. Keep us posted on that rocket! Greg
jdnca1 03-16-2005 10:22 AM
Hardin Marine made the guages in my Eliminator.....most senders will work but must match the range on your guages. Another words, don't try to use a 0-100 psi sender for a 0-80psi guage.....
I switched all of my guages to livorsi last year and did not have to change any senders...BUT I matched the ranges to what I was taking out.
