transmission shifter bracket
I am putting in two Huber cryptonite trannys and was needing some input on how to make up a shifting bracket, I assume it bolts on the back of the transmission? Any help and pictures would be appreciated. They are driveline models with a lots of room behind them.
Re: transmission shifter bracket
I dont know if tou solved this yet but on one of my boats the cables are latched into the standard cable clamp like on a carb bracket that is mounted to the driveshaft cover housing. you could also make a plate off of yours if you have a setup like that.
My other boat has them coming from the opposite direction with a stand off bracket mounted to the side of the trans. You can still use the stck setup if you can find an old tranny to scab the parts. Hope it helps |
2 Attachment(s)
This is the arangement on mine. Don't know if this helps. The cable fastnes to the stud then the cable ond goes to the bellcrank.
Thanks, that helps. Anyone else with any other pics?
i ahve those parts, and if they wont work we can desighn and make something case specific
Hey imonstaa, I think I met you at Key West at the Hilton pool. Are you from Long Island?
1 Attachment(s)
This is the best picture I can dig up at this late hour, and it was taken prior to cable installation, but all I did was take a piece of 304 stainless barstock, bend it 90 degrees, drill it for the transmission bolt, bolt or weld the Morse 33C bracket to it in the right spot, and you're on your way. You do end up with a bit of bend in the cable, but I used Supreme cable which can easily sustain the minimal bend, and it works like a champ! Mine is a plug-in so I couldn't go from behind. You have a lot more options available.
YES I AM. WAS THAT IN THE HOT TUB? Hope i wasnt a lil primed and offensive! just kiddin. |
here is a pic from the bam website . this is a basically the linkage set up for borg warner trans .
http://www.mercruiserparts.com/Show_...+SHIFT+LINKAGE |
1 Attachment(s)
I bought 15 Huber 1200's last year at a government auction. These are the brackets that were on them, I have a few left and will let them go cheap if you can use them.
| All times are GMT -5. The time now is 04:07 PM. |
