-   -   525 SC Knock Sensor? (https://www.offshoreonly.com/forums/general-q/98647-525-sc-knock-sensor.html)
Scott 03-19-2005 12:58 AM
Does this engine have one? If not what would be the best route to take for knock protection/monitoring. I have seen the Livorsi gauge just looking for alternative systems.
If anyone has one they are not going to use or pulled off an old set up let me know.
Griff 03-19-2005 03:48 AM
Re: 525 SC Knock Sensor?
No knock sensor on a 525sc that I'm aware of.
Strip Poker 388 03-19-2005 05:16 PM
I would think it would ?It would be beside the drain holes on the oilfilter pad side .shurly it does?
Griff 03-20-2005 03:42 PM
Nothing on the diagrams in my 525SC manual either. Its a standard TB IV ignition with a merc rev limiter.
Don't you need have a TB V to have the knock sensor with timing retard feature???
JaayTeee 03-20-2005 05:22 PM
TBV 525's have a knock sensor.
A friend of mines 97's have TBV,
I believe that was the first year for
it.
Strip Poker 388 03-20-2005 11:34 PM
Sorry I was think about the 525 efi.
Scott 03-21-2005 08:07 AM
Sorry I should of mentioned carbs. So some do and some don't depending on the year and if they started using a V instead of the IV?
