Installing pop-up cleats
I ordered some Accon pop-up cleats and will be installing them soon. I am assuming I just need to use the backing plate as a templete and cut out a matching hole in the deck with a jigsaw. Is there anything else to it that I need to be prepared for? Thanks
Re: Installing pop-up cleats
Just make sure you have the clearance behind the cleat! No bulkheads, electrical wiring, fuel hoses....etc. Are you installing the ones that have the drain cups? You will need to be able to run the drain line around so it empties into the bilge and not all over the interior of the cabin :)
I always use an airsaw with a hacksaw blade, grind the back of the blade down to enable it to go round tight curves easier, then clean up the cut hole with a dremel!
put down some blue painters masking tape on the deck so you dont scratch it up and keep the gel from chipping on ya too :)
Wally,
Ditto on the painter's tape to protect your fiberglass. It will also help prevent "chipout" due to cutting. Personally, I'd dispense with the airsaw and the jigsaw and use a RotoZip which is basically a Dremel on steroids (sorry Jose and Mark). Make some practice cuts first in some scrap wood or fiberglass if you have access to some. The RotoZip can be a little tricky to control until you have a little practice but it will yield outstanding results. Think of it as a handheld CNC machine. Your brain is the computer and your hands are the hydraulics. The cost to buy a good model is under $140 and cheaper ones can be had for well under $100. If you get one, you will use it a lot. I wish they would cut metal though. |
Put masking tape over where you are going too cut as others have said.
I also recommend using a rotozip tool or equivalent to cut. Do not use a saw, it will hack it up. |
Monty.....if you want to try your hand with a roto-zip i can lend you mine :)
What price did you pay for the 6" & 8" Accon Pop-Ups? Ed
If the deck where you cut through is wood cored I would resin coat the wood after you cut the hole,before you install the cleat.
You may need more than one blade. Fiberglass and gel coat eat them up fast and pushing a dull blade leaves a bad cut.
Thanks for the reply's. I've got a Rotozip tool I'll try that first, but I've never had much luck with it. The bits always seem to break on me, even in drywall. Maybe I'm trying to push it too fast.
I'll be sure to seal up the deck where I cut into it, thanks for the advise. Ed, I bought the cleats from Fred (Trick Marine), his prices were about 40% cheaper than buying them from Accon directly. |
Just go slow with the Rotozip and you will be fine.
Makes me itchy just thinking of it. :-). I installed a wakeboard tower on the boat and used a air powered version of a roto zip. Cuts really good, just go slow and keep a hold on it to minimize the chatter. You also can buy a carbide end mill for much less $$ to replace the bits.
| All times are GMT -5. The time now is 02:38 PM. |
