Engine builders offering 800 HP NA?
I remember seeing Paul Pfaff advertising a 598 with tunnel ram converted to EFI that made 800 HP. Anyone have experience with that engine or others like it?
Re: Engine builders offering 800 HP NA?
We do an 825 EFI that makes power at 6000 RPM's. The engine was designed for cats. It comes w/ a 6 month warranty, and is serviceable by any Mercruiser dealer.
Tomcat
How's it going hope all is well . We made an offshore first release in Feb. just after the boat show on a new MB800na based on a 632ci carb engine and we also offer that in an EFI configuration. All of our power is in by 5600RPM and the rev limit is set at 6000 this is a killer combo we've tested this combo for the past two years in the race circuit and I just sent two to Kuwait carburetors the guy loves them.Sincerely Laz Mesa |
What are the pricing for the 700 and 800 na engines ?
Don |
Don |
I'll bet very close to what a new Merc 525 costs.
Max Hp in a Zul Engine (Normally Aspirated)
750 hp+ @ 6000 rpm – 598 cubic inch displacement – Dart Pro 1 Ported Heads – Dart Single Plain Manifold – 9.5 to 1 compression ratio – 91+ octane fuel requirement – Roller Lifter Camshaft – 1090 4-barrel carb With a Blower: 950+ hp @ 5800 rpm – 686 cubic inch displacement – Dart Pro 1 Ported Heads – Supercharged - 1071 – 8.5 to 1 compression ratio – 91+ octane fuel requirement – Roller Lifter Camshaft – Dual 900 4-barrel carbs All Zuls have: Dart Engine Blocks – 4340 forged steel crankshaft – Oliver Billet connecting rods – 200 wall wrist pins – J&E Forged silicone aluminum pistons – Keith Eickert aluminum oil pans – Stref's Race Oil Pans – High volume oil pump – Internally balanced – Complete wire harness – Die cast aluminum valve covers – Complete sea water cooling system – High torque starter – Billet remote oil filter mount – 90 amp alternator – Heavy duty oil coolers – Electronic ignition system – 8mm spark plug wires – Rollerized rocker arms Price?? 80 Kean Street, Building 1, West Babylon, NY 11704 Tel: (631) 491-7268 Fax: (631) 491-4739 |
750 hp+ @ 6000 rpm – 598 cubic inch displacement – Dart Pro 1 Ported Heads – Dart Single Plain Manifold – 9.5 to 1 compression ratio – 91+ octane fuel requirement – Roller Lifter Camshaft – 1090 4-barrel carb 950+ hp @ 5800 rpm – 686 cubic inch displacement – Dart Pro 1 Ported Heads – Supercharged - 1071 – 8.5 to 1 compression ratio – 91+ octane fuel requirement – Roller Lifter Camshaft – Dual 900 4-barrel carbs All Zuls have: Dart Engine Blocks – 4340 forged steel crankshaft – Oliver Billet connecting rods – 200 wall wrist pins – J&E Forged silicone aluminum pistons – Keith Eickert aluminum oil pans – Stref's Race Oil Pans – High volume oil pump – Internally balanced – Complete wire harness – Die cast aluminum valve covers – Complete sea water cooling system – High torque starter – Billet remote oil filter mount – 90 amp alternator – Heavy duty oil coolers – Electronic ignition system – 8mm spark plug wires – Rollerized rocker arms Price?? 80 Kean Street, Building 1, West Babylon, NY 11704 Tel: (631) 491-7268 Fax: (631) 491-4739 |
Originally Posted by sutphen30
i'm a brokeher. :D you build them,i'll breakem. :drink:
is all the 800hp n/a's big cubes,anyone doing it w/ say 555 or 565ci? JC will build ya a 800 HP 454..... :cool: :cool: |
Originally Posted by JCPERF
Hydro,Do you want to be an engine broker? :D
PM me with a deal and I will broker for you. I could probably get you 10 orders a year. that's how many engines my neighbor goes thorugh.. :p |
| All times are GMT -5. The time now is 01:22 AM. |
