-   -   304 vs 316 Stainless Steel (https://www.offshoreonly.com/forums/general-q/99105-304-vs-316-stainless-steel.html)
JohnJan 03-28-2005 11:13 AM
Re: 304 vs 316 Stainless Steel
1 Attachment(s)
Here's a sketch of the doo-dad. The intent is not so much to provide cooling water to run the boat for long periods of time on the hose, but to provide water to the impeller to keep it from burning up.
I really only need to be able to start the engines before I go to the lake to make sure all is well before I hit the boat ramp.
Poorsche 03-28-2005 12:25 PM
There are a "few" manatee zones over here--but lots of open water too. Just have to stay way from Port Canaveral really.
GGB 03-28-2005 02:23 PM
1 Attachment(s)
We have 1.25" OD 304 bends available if you can't find any locally.
Wall thickness is .049" (18 guage). Mandrel bent at whatever dregree you require. Starting with a 12" long pc before bending - 20.00 each.
Graham
GGB 03-28-2005 02:26 PM
Now that I look at your drawing a little closer you aren't after a bent piece, but rather a staight piece. We can do that too. 8.00/ft
Graham
JohnJan 03-28-2005 02:59 PM
Thanks Graham, I can get 304 locally for about $6.00 a foot. And all I really need is a coupla feet. One foot to screw up and the other foot to get it right...
GGB 03-28-2005 03:12 PM
Cool. The shipping would cost more than the material.
vonwolske 03-28-2005 07:24 PM
I think the grab rails for handicap toilets is 1.25 OD. They are Stainless steel and you can maybe use the bent portion if you desire a slight elbow. I would braze in the 1/2 feed line at an angle. Silver brazing with silfos requires minor fit-up, but can be done with a file and patience. Call Johnstone Supply just south of Ben White Blvd.
I used copper sweat fittings to make nice elbows for my strainer. Any good plumbing or refrigeration supply house.
I know how fanatical you are about these things, but even copper will outlive both of us in fresh water.
JohnJan 03-29-2005 09:35 AM
I'm sure you're right Jim, I can TIG weld the SS easier than braze copper.
