-   -   new 496 mag in older boat tach issues (https://www.offshoreonly.com/forums/general-q/99278-new-496-mag-older-boat-tach-issues.html)
smokin' gun 03-28-2005 06:16 AM
just installed a new 496 mag in my 89 formula i just plugged in the harness and started but i have no tach my guess is the signal is wrong for the tach vdo i had this same prob w my 357 when i put msd ignition in i needed tach adapters but this system is 8 coils no dist anybody got any ideas
89scarab3 03-28-2005 11:11 AM
Re: new 496 mag in older boat tach issues
I Would Guess Your Tach Is Analog And Your Motor Is Outputting Digital.
I Put 496's In My '89 Scarab, But The Only Gauges That No Longer Worked Were The Oil Temp.
Dave M 03-28-2005 02:59 PM
I went from a '97 454 Mag MPI to a 496 HO, no problems. I guess your old engine was a carb? I think MPI/EFI and carb engines have a different harness.
Pat McPherson 03-28-2005 09:34 PM
I would compare a schematic of the old engine harness against the new.
I bet the tach wire is on a different pin.
Or you have a broken wire.
Bad grounding or a bad ignition switch can screw with your tach as well...
Lofty 03-28-2005 11:05 PM
What ignition are you running? What ignition was on your old motor? My guess is that you have the Merk Racing tachs? These ONLY work on the old style T-Bolt ignition, it's an outboard set up.
