-   -   I.T.S. and a stock Bravo 1 What has to be changed (https://www.offshoreonly.com/forums/general-q/99306-i-t-s-stock-bravo-1-what-has-changed.html)
magnum27 03-28-2005 12:17 PM
I have an I.T.S. transom assembly that I am about to install on my boat and was wondering what parts will have to be changed on the drive in order for it to be mounted. It is a slandered Bravo 1. I know of coarse that I need a longer shaft as the I.T.S. has a seven inch set back, but who can sell me a shaft for a standard bravo to fit it. Also will anything else need changing?
Mbam 03-28-2005 01:12 PM
Re: I.T.S. and a stock Bravo 1 What has to be changed
The shaft might be a problem, as the one Merc makes is for an XR
magnum27 03-28-2005 02:19 PM
does anyone know someone who could make a shaft that would work? Or be able to take the shaft from an XR and weld on the end for a standard Bravo so it could work
Mr Gadgets 03-28-2005 06:03 PM
magnum27,
I think you meant to spell standard Bravo 1? If so, You could get a set of XZ gears, I dont think the pinion is sold seperately, and you would need the clutch, universal joint assy, shift fork and all the bearings. In other words a total upgrade kit, but using the XZ gears. That would give you the stronger gears, but then you dont have a steel tower. Sounds like the easiest way is an XZ upper, then you need the gimble bearing kit. I have done some mixing and matching to accomodate things like this. Shoot me an email if you have more ???? or want some info on it..
Hope this helps.
Dick
plumbers crack 03-28-2005 06:45 PM
Just had my drive re done with the longer shaft for ITS.You need to order a new bearing,spanner nut and carrier from IMCO about $250.00 the shaft is about $850.00 It is only sold complete with gear and universals MRD charged $250.00 to assemble for me.The shaft is an XR.Good Luck
magnum27 03-29-2005 08:23 AM
Quote:
That's what I needed to know, doesn't sound to bad, thanks for the info
