anyone ever have cam bolts back come loose?
i forgot to bend over the tabs on the little plate that holds the cam button on the nose of the cam. i tightened the bolts well and was wondering if it is worth the truoble o go back in (new one piece pan and timing cover gaskets) and bend them over. the guy at the machine shop said he has never seen cam bolts come loose. what are your thoughts? do i let it ride?
Re: anyone ever have cam bolts back come loose?
I had a set of cam bolts shear off last year.
Why? Probably because they loosened up... Could not find a cam bolt lock for a gen VI so red locktight it is. Gaskets are cheaper than belt valves... :eek: |
Yea, if you didnt locktite them, Id open it and do them right.
I agree, if you didn't locktite the bolts, open it up now.
I loctite mine as well,,,
Locktite or bend those tabs!!!!!
done, thx for the advice, i just put in a grand worth of manley valves :eek:
Thats what I was tinking about.. if something did back out.. what kind of mess it would make. It would keep me up at nite knowing you didnt do it Ratman.. Ok.. I have enough to worrry about already.. better do it man!!
Use the hi quality bolts like arp.
i used the bolts that came with the locking plates. thye look like grade12.
| All times are GMT -5. The time now is 01:14 PM. |
