-   -   Rev Limiter Question (https://www.offshoreonly.com/forums/general-q/99661-rev-limiter-question.html)
Gizmo 04-01-2005 11:35 AM
I have a pair of carbed, 95' 500hp's. Are the rev limiters adjustable or are they fixed? If adjustable, how is it done and if fixed, what needs to be done to increase the rev limit?
Griff 04-01-2005 03:03 PM
Re: Rev Limiter Question
rev limiters are fixed. You can simply remove/bypass them. Its a black box mounted near the module.
excursion 04-01-2005 05:19 PM
On the 95 HP there are no rev-limiters, you have the TB IV module. That are the ones I just put in my boat.
Griff 04-01-2005 05:52 PM
There IS a separate rev limiter on all blue/merc racing engines with TB IV ignitions. It is a separate component and can be removed.
It is part # 41 in the diagram on the link.
http://www.mercruiserparts.com/Show_...CAL+COMPONENTS
US1 Fountain 04-01-2005 05:53 PM
My '94 HP motor had a rev limiter.
baja36ft 04-01-2005 07:16 PM
Hey griff,how do you remove it?????
excursion 04-01-2005 07:33 PM
On my friends 95 HP there was no rev-limiter, someone must have removed it prior.
Learned somthing new everyday.
baja36ft 04-01-2005 07:46 PM
I have a 1999 hp500 that has a rev limiter that i want to remove but not sure how to!!!!!!!!!AND YES IT IS A CARB
US1 Fountain 04-01-2005 08:57 PM
Here guys........... And only $38 from Merc.
http://www.offshoreonly.com/forums/s...7&postcount=17
US1 Fountain 04-01-2005 09:01 PM
The rev limiter in my link #43 is the same pt # as Griffs pt # 41, just so no confusion.
