-   -   checking fuel delivery system (https://www.offshoreonly.com/forums/general-q/99898-checking-fuel-delivery-system.html)
bowtie 04-08-2005 08:41 PM
Re: checking fuel delivery system
The vacumn test will tell you if there is a restriction, collapsed fuel line, clogged filter or bad anti-syphon valve. You can also pressure test the system to see if you're sucking air anywhere. Fuel pump pressure should be checked with a pressure guage.
Strip Poker 388 04-08-2005 11:22 PM
Originally Posted by bowtie
The vacumn test will tell you if there is a restriction, collapsed fuel line, clogged filter or bad anti-syphon valve. You can also pressure test the system to see if you're sucking air anywhere. Fuel pump pressure should be checked with a pressure Gage.
Thats not a bad Idea .I guess it would tell ya Like if a steel braided hose is going bad collapsing restricting flow?
Question it there any fuel pumps create enough vacuum to give a false reading on the vacuum gage?
thanks for the info :D
Rob
