help me does shaving weight gain mph
if i shave 100lbs. will i gain mph?? how much should i expect for every 100lbs. on a 3750 lbs. boat ?? thanks for your help
Maybe 1 Mph........if you are lucky
Tough call, on some pleasure boats maybe nothing. I'm interested to see the variety of answers on this one. How much does it speed up low on fuel. That is probably your best test every 14 or 15 gallons is a 100 lbs approx.
Jim |
Originally Posted by Smiklos
(Post 2282904)
That boat weighs more then 4300 lbs. On a straight V single a 100 lbs is around 1 MPH. Mike Carter had a boat like yours we made some simple changes it liked.
Look at the tabs see if they are dragging engine needs more air Hook is large Steve |
Steve is suggesting other ways to find speed. Do you recognize the terms he used?
Jim |
Originally Posted by MOBILEMERCMAN
(Post 2282948)
Jim |
What type of trim tabs do you have? Some brands can be installed in such a way that the drag in the water. He found with his buddies boat the engines liked more air available in engine compartment. Hook refers to the contour of the bottom. A hook helps it ride nice but reduces speed. MPH doesn't often come easy in boats, the things Steve mentioned are generally the easiest path to search. Its good info being he knows the boat.
Jim |
(Post 2282995)
Jim |
Don- that sounds like a good excuse for a boat ride. Do the test. I'm not familiar with your exact boat to know. Some boats are more weight sensitive than others. To answer "If you can expect 6mph or more" I would say no, Maybe a couple. There are countless variables involved with weight and speed in boats. Taking weight from the bow will have a greater effect then else where. Good luck.
Jim |
(Post 2283030)
Jim |
In a boat running light won't net you six mph but just leave your friend on the dock lose some fuel and see where it takes you. Just a good straight line without scrubbing speed could net you a few. But if you do not know what a hook is or dragging tabs that is better left alone for now. Good advice Steve.FYI I wouldn't think he is your friend if you tell him to stay on the dock today I am gonna go faster.Mods may be the better route.
Originally Posted by Donzilla
(Post 2283070)
Why not just run the boat with GPS, add 100lbs, easy enough, and run it again before pulling things out of the boat.
My 29' Scarab is very sensitive to weight, the more gas I burn from the tank the faster I go:D(but only a few mph) And yes they do have some major hook, not sure about the 23' bottom though. The hook will prevent the hull from airing out even without the weight.
NO way you will get 6 mph for 500lbs. Maybe 2-3 at most. My 24 outlaw is much more weight sensitve than my 32'.
| All times are GMT -5. The time now is 07:52 AM. |
