Go Back  Offshoreonly.com > Race Talk > General Racing Discussion
VHF Antenna Where do I mount it? >
Old 05-23-2008 | 03:33 PM
Default VHF Antenna Where do I mount it?
Class 5 OPA where should I mount VHF Antenna for best results? I bought the 3 foot stainless one and a mount to put it on the bow rail? any ideas ?
GoFastSonic is offline
Old 05-23-2008 | 04:17 PM
We have ours in the cabin, and it works fine.
HighPriority is offline
Old 05-23-2008 | 11:37 PM
Is it on a mount or just wire tied up?
Old 05-25-2008 | 08:56 AM
Mounted to a stringer.
Old 05-25-2008 | 08:10 PM
Old 05-25-2008 | 08:38 PM
CcanDo's Avatar
Just another option....You might try a 7 or 8" rubber whip similar to an antenna used on a handheld. The antenna base would mount above deck,CNC connector (threaded type preferred) and a S/S backer plate of 8"x 8" would mount below deck....The backer plate should be grounded,creating a ground plane.
Note: when the antenna is removed from the base, water can enter the co-ax and cause corrosion. Corrosion can change the ohm value and RF performance.
CcanDo is offline
Old 05-25-2008 | 08:44 PM
Thanks CC
mrpickett357
Cigarette
13
09-21-2005 06:38 AM
38SprtCruzKev
Fountain
9
06-06-2005 10:52 PM
Elite Marine
Pantera
2
03-31-2005 07:32 PM
RedDog382
4
03-03-2005 12:08 PM
rv
12-22-2002 09:30 AM
