-   General Racing Discussion (https://www.offshoreonly.com/forums/general-racing-discussion-194/)
-   -   Rules for SVL (https://www.offshoreonly.com/forums/general-racing-discussion/249429-rules-svl.html)
heater63 03-16-2011 09:41 PM
its also doughtful you would be competitive with the 6 drive.too heavy and robs to much horsepower.Invest in a good throttleman instead!!!!!!!
521 Racing 03-16-2011 11:16 PM
The #6 work for cat light but I'm looking at other drive that are lighter. Its more about safety for me and others. I've been in a boat that spun out because the Bravo drive failed.
Hey whats with the speed rule now I'm trying to leave the P Classes?
Ryan Beckley 03-17-2011 09:05 AM
Let me guess.... you want to use a Weismann drive? Do you also realize that you'ld be able to buy 5 bravo props to one #6 prop?
fantastixvoyage 03-17-2011 09:45 AM
Your comparing apples to oranges...
#6 work in supercat light because everyone in the class runs them. As mentioned with 525s rarely is there a bravo break in SVL. If you want to run something, I'm sure no one will have a problem with you running a wet sump six :grinser010:
As for the spin-out was it a single engine or twin? Wont say it cant happen but dont really hear much about a broken drive on a single "causing a spin". Twin engines sure cause the other drive it still under power.
Your comment about the speed limit in SVL makes me believe you may not have done your homework on this class. In a nutshell there is no speed limit - its all about optimizing your setup and running flat out. Everyone runs the same power so setup of boat, drive, etc is key. You cant just keep throwing more power at it like P-class. That's why running a bravo is so well accepted - lowest parasitic losses and can handle the 525 class just fine (oh and the drive allowed by the rulebooks makes if a favorable choice as well :drink:)
Anyways, hope to see you out there one way or another.
SVL4 03-17-2011 10:11 AM
Very well said!!
Wil
521 Racing 03-17-2011 02:49 PM
I'm looking at Weismann & Arneson drives for the boat. I don't want to go through the Bravo drive and have it check out every couple of races, changing the oil is one thing that is a must. The boat that I was in was a twin, the gears were fine it broke around the gimble housing. the drives only had 30hr it and the motors were 525s. I've seen other bravo's that were singles to have problems to. They found the problem be for they faild all the way. The motors were 525s and 575s.
I know of two boats in the that had good luck with the Arneson and Weismann drives. Those drive's wont make the the boat faster will they?
I want to get a boat ready for 2012. I like the class, it reminds me of the old A class. There was over 10 boats in every race.
Wahoo ATV 03-17-2011 03:29 PM
No speed limit unless you build a new boat that will beat all the old boats.
heater63 03-17-2011 03:33 PM
Dean are you talking about the skater beating the fountain super vees
Wahoo ATV 03-17-2011 06:23 PM
A little bit but not really. Because in that example the rules where changed to allow #6 drives and more aerodynamic hull shapes. It was a rule change which obsoleted the older SVs. What happened in SVL was much different. As you know.
Also as you may remember Spiderman was wieghted down which was in effect a speed limit. Just like the new OPA parity rules for the vintage SVL class. Didn't I hear 92mph thrown around?
DareDevil 03-17-2011 07:22 PM
NOBODY IS GOING TO CHANGE THE RULES FOR YOU !!!!
So either you run what the rules say , or your just not racing..very simple !:coolcowboy:
