-   General Racing Discussion (https://www.offshoreonly.com/forums/general-racing-discussion-194/)
-   -   Suspension seat user question. (https://www.offshoreonly.com/forums/general-racing-discussion/304732-suspension-seat-user-question.html)
Bilgerat 10-29-2013 02:29 PM
I know there wont be many people that can respond to this question, but to the folks running race boats or pleasure in suspension seats, Are your throttle controls attached to the seat, so they move with you up and down, or are they rigid to the boat ? Do you like it either way, and is it easy to be smooth if they are in the boat and not the seat. I would suspect most of them are rigid to the boat, but am wondering how that works out as your body is moving independantly of the controls.
Viperfitness1 10-29-2013 03:00 PM
mine are independent. they give a floating feeling so its nice to have the throttles rigid to use as a bit of a handle. i have a rigid handle on left hand also for tabs and trim. my forearms are usually smoked from holding on so tight and i have to remember to relax in the seat and use my legs for support for the best ride. still a night a day difference in rough water.
Xtremeracing 10-29-2013 10:32 PM
Ours are rigid and have no issue at all.
smiklos@sunprint 10-30-2013 08:11 AM
Same here although Gary complains about the Wheel being fixed and him moving.
Steve
Viperfitness1 10-30-2013 10:09 AM
i could be wrong but i think remember seeing a outerlimits or statement that had shock absorbers on the entire cockpit. it was a open canopy pleasure boat i believe.
smiklos@sunprint 10-30-2013 01:10 PM
Statement does for sure.
Steve
Bilgerat 10-30-2013 04:33 PM
Im working on a design for the Corsa, and Maybe the deal will be to have standard single engine two handle controls in the console like normal, and then an additional THrottle only handle setup that rides with the throttlemans seat. This could even be removable. Its just more work, and expense, which I wasnt too interested in, as long as you guys are having good luck with them rigidly mounted, I think thats what we will do for starters. I would suspect it would have to be more easily controlled if it went up and down with you, however. Thanks for the responses.
jerryhaney 10-30-2013 08:35 PM
Seats
I did both on a 38 Fountain as a test for myself. The people in the boat never new or said a word. Put it where your comfortable.
