New 5 Blade Prop
1 Attachment(s)
A new 5 blade prop is available from Hyrdromotive called the P 5X. They are based on the Quad IV X, also from Hydromotive. This prop is a bow lifting prop which will work on some boats that need a bow lifting type prop.
The hub has the square bore so it will accomodate the Flo-Torque hub system from Mercury. Allowing the prop to fit on almost any large gearcase outdrive. Including both the large (XR) and small prop shaft. This prototype is a 27 pitch which will work in place of a 29 or 30 pitch Bravo 1 prop. Matt Throttle Up Propellers |
This is a great prop for the price, thank you Julie for introducing it to us.
Chris Reindl |
Your Welcome. Now who's interested in testing this PROP!
Julie |
P5 -X ...great for P5-66
Bruce, I am assuming that you will be attending our dial in session in February!
And don't forget to bring your sunscreen! Julie |
I will certainly try. If I cant make it, Trent will be there
That bald head can fry!!!
Outer 42 will you be joining us in February?
no,you said you don't have blades for #6. i would love to try a 6 blade for a #6 i run a 5 now. herring.
YA, YA, YA, YA I remember now!
Julie |
| All times are GMT -5. The time now is 04:30 AM. |
