Prop ???????
Here we go.
I have a 99' 32' AT that had 2-500hps i have installed the OSO gadiotor 500efis last year. This winter I had the props redone, now they hit the rev limier on the efis. I have 28 merc bravo props. The boat jumps out of the hole. What props should I move up to? I dont know how you guys go and test props all the time, will deallers let you demo them or do u buy them hoping that they are correct. thanks fellas Randy |
Every inch you go up should bring down your RPMs by about 200.
Call Julie!!! |
Randy,
Can you define "redone". Do you know what work was done to the props? Prop work can change the WOT rpm dramatically. We can take a look at your props or we have test props you can try out as well. Just give us a call if we can help. Matt |
Wild: Note your target RPMs, your current speed when the rev limiter is hit, and your target speed. Then call Juilie at 877 842 6855
| All times are GMT -5. The time now is 08:56 PM. |
