Surveyor in Tulsa, OK?
Any of you guys know a surveyor in the Tulsa, OK area? For the most part, I just need someone to put their eyes on the boat, check for moisture and electronics as I'm buying without power. Thanks for any suggestions you can send my way!
You might try calling Ughly Johns at grand lake. I used a surveyor about 5 years ago that did alot of there marine surveys. Be prepared to spend a little coin. If I remember correctly he charged me $12 per foot plus about $5 per mile if he has to drive to view the boat.
Originally Posted by powercat
(Post 3524973)
Ben Harman used to do them in the tulsa area.
Originally Posted by carter38
(Post 3527004)
I talked to Ben but he was so busy, he couldn't get to it for at least 2 weeks. The boat also ended up going to Joplin, so I found someone close to there, survey will be done on Tuesday. Thanks for the suggestion! |
Originally Posted by TCBoss302
(Post 3527168)
Carter,
I talked to Ben but he was so busy, he couldn't get to it for at least 2 weeks. The boat also ended up going to Joplin, so I found someone close to there, survey will be done on Tuesday. Thanks for the suggestion! You might mention which boat it is you are looking at. Chances are that if the boat was in this area, plenty of us on here know about it and could tell you plenty. |
Originally Posted by mroberts
(Post 3528892)
TC -
You might mention which boat it is you are looking at. Chances are that if the boat was in this area, plenty of us on here know about it and could tell you plenty. http://www.offshoreonly.com/forums/g...a-ok-area.html |
The question is what is Larry going to replace it with.
http://www.offshoreonly.com/forums/g...a-ok-area.html[/QUOTE] Here Kitty Kitty Kitty! lol |
Originally Posted by E Dock DD
(Post 3529009)
Matt you are right that we might know the boat. It is LV's Outerlimits. The below thread is how I know. The question is what is Larry going to replace it with.
Yes the boat looked brand new in person the last time I was around it.
