-   Great Lakes and Canada (https://www.offshoreonly.com/forums/great-lakes-canada-219/)
-   -   August 7th LEOPA Fall Run (https://www.offshoreonly.com/forums/great-lakes-canada/302226-august-7th-leopa-fall-run.html)
POWERPLAY J 08-30-2013 07:42 PM
Ok so if we can get Dave, you and Phragle to pay for gas and I find my bum trim issue I might be able to make it. I will know by Mon if I can cancel my other plans and if the boat is ready.
phragle 08-30-2013 07:51 PM
Whats your trim doing???
POWERPLAY J 08-30-2013 08:21 PM
Lost all four relays and both trim motors last Sun. Talked to Orlandi today after my mechanic checked it out. Heading down tomorrow to see if I can do good. If not then it will be going to Brian.
phragle 08-30-2013 08:38 PM
anything work if you jump it with direct power and ground??
POWERPLAY J 08-30-2013 08:45 PM
Yes, tried jumper wires to all. But after my talk with Brian I will look into it myself. There is almost no way six went bad at same time. Going to start at grounds and work my way back through everything. If I can't figure it out I am dragging it to him cause as we know he is the master...
phragle 08-30-2013 08:50 PM
Obi Wan Orlandi, the force is very strong with him.
POWERPLAY J 08-30-2013 08:55 PM
Yessir. He is awesome...
POWERPLAY J 08-30-2013 08:58 PM
Oh, btw. If it does happen Dave wanted in and you are welcome too. I just gotta figure this **** out and see if I can make it happen.
