Pictures and Completion
How about some new pictures,specs and status on its completion ??? Bud
I would like to know why you put a 12'3" beam on a 38' boat.
Originally Posted by Catmando
(Post 3507090)
Look at the Magnum 44, 53, etc... none of these are in the same class as the 8-9ft beam boats you see here on OSO. The 38 is actually the one I can't wait to see done, especially since we owned a 1976 Flybridge Model. My 4th grade class pic... I was wearing a Magnum T-shirt. :D |
Correct
You are 100% Correct Sir. We are going to 100% redesign the Deck and use the Magnum 44' only cut it down. We are tryin to make a GTMM 38' that is affordable and a introduction to larger Magnums.
GTMM 27 and GTMM 39 Specs
Here are Specs- As far as Pictures we will when we get farther along. We have a booth at the Miami Show come see us then. We will post some pictures before the show. We want to hold off, people steal ideas in this Industry.
GTMM 27 Hull Design: Mono-hull 5-axis computer tooled Cockpit Configurations: Two front seats separated by the console and rear seat bench Engine Layout: Single Length - overall: 28’2” (8.58m) Max Beam: 7’10” (2.38m) Displacement: 5,000 lbs. fully loaded with fuel Fuel Capacity: 130 US gallons (492.10 liters) Deadrise: 24 degrees Engine Options: Mercury 496 Mag HO, 525 SCI, 662 EU, 700 SCI Speed (appx): 70 MPH + GTMM 39 Hull Design: Mono-hull with 2-step, 5-axis computer tooled proprietary ventilated bottom technology and full running surface pad on bottom. Cockpit Configurations: Canopy-style with sit-down side-by-side front seats and rear seat bench. Fully enclosed canopy with sit-down side-by-side seats with 2 optional rear seats. Fully Open version with wrap around windshield. Engine Layout: Side-by-side or staggered Length - overall: 39’0” (11.9m Max Beam: 8’6” (2.6m) Max Height: 6’2” (1.9m) Displacement: 8,400 lbs. fully loaded with fuel Fuel Capacity: 240 US gallons (970 liters) Freeboard: 43” (109 centimeters) Draft Static: 36” (91 centimeters) Deadrise: 24 degrees Engine Options: 496 HO – 1350hp Mercury Racing Speed (appx): 85 MPH + |
Originally Posted by ssmith76
(Post 3510655)
Price
What Model are you referring too?
Wide Beam 38'?
If you are refeing to the wide beam 38' We want it to come in well under $1M.
That's the answer I thought would come. A flybridge on an 8'6" boat would be dangerously top-heavy and 'tippy'. REPUBLICANS LIED AND THE ECONOMY DIED |
(Post 3521510)
That's the answer I thought would come. A flybridge on an 8'6" boat would be dangerously top-heavy and 'tippy'. REPUBLICANS LIED AND THE ECONOMY DIED The 38 is not 8'6" beam. |
| All times are GMT -5. The time now is 04:34 AM. |
