-   Hustler (https://www.offshoreonly.com/forums/hustler-38/)
-   -   What to expect? (https://www.offshoreonly.com/forums/hustler/184119-what-expect.html)
BY U BOY 04-09-2008 04:53 PM
What to expect?
Out of a 377 talon with 530hp aluminum small blocks turning 7200rpm's with 6's.
PR set up.
Just wondering what kind of speed it would see.And how the boat would handle with the azz end being lite.
Strip Poker 388 04-09-2008 11:08 PM
I would thick a small block boat would have no low end TQ,Hard getting on plane etc.
530 is kinda low HP for all alumium SBC motor and 7200,must be a 350ci,small headsa and around 9.5cr?
WildWarrior 04-10-2008 06:15 AM
PR set up.
The 377s are great riding boats until you hit real big water.
She would probably handle better as she may fly level when leaving the water or hitting large wakes ,they tend to launch bow high . They are pretty heavy boats even with small blocks and with 11% slip on a good day I would guess she may tap the high 90 mph mark.
Good luck!
BY U BOY 04-10-2008 09:27 AM
Motors actually make 620 HP 695T but will be detuned if the project goes thru. Not sure what the exact torque #'s will be after detuning.
BY U BOY 04-10-2008 09:30 AM
Good luck!
Boat would be built with a very lite lay up.
raceday500 04-10-2008 06:37 PM
377 w/575
Spoke to Henri from Performance Marine Specialties and the Talon with 575's ran 110 to 112 mph. Should give you a close idea of possible speeds. I'lll have Henri give you a call tomorrow he has tuned up more talons than anyone.
John
WildWarrior 04-11-2008 07:45 AM
John
Is that 110mph with #6s or with Bravos?
Strip Poker 388 04-11-2008 01:36 PM
In Nov2002 I was at lake cumberland ,Randy told me the 377 with 575 they had would run 120-125, I think it was a bravo boat
OL40SVX 04-11-2008 01:45 PM
I dont think so. A guy i know had one and it would run 108-110 with bravos then around the same with sixes.
frogger1403 04-12-2008 01:11 AM
377 with 525 = 120mp/h is bull****
It will run 108-110mp/h.
Heiko
