-   Hustler (https://www.offshoreonly.com/forums/hustler-38/)
-   -   Hustler Info Needed (https://www.offshoreonly.com/forums/hustler/194109-hustler-info-needed.html)
Elite Marine 08-27-2008 08:53 PM
Hustler Info Needed
My Cheetah appears to have had a battery charger in it at one time on the Port side above the battery. I'd like to know what else this could have been?
What would it take to add shore power?
What is the bilge painted with? Color code and Brand?
What size and model numbers are the hatches in the newer models? Mine does not have hatches and its very warm in there!!
The trailer Is not nothced for the steps and there are chips and cracks in the gel at the steps. Should I trim the trailer bunks for relief at the steps? Or was this simply caused by someone driving the boat off the trailer and not floating it off?
Strip, use these as chapters in your "Hustler" book and I'll buy the first copy!!
raceday500 08-29-2008 10:24 AM
cheetah
call me with your hull number and I will see if I can get you all the information you need.
631-208-2933
John Cunningham
Hustler Powerboats
Elite Marine 08-29-2008 03:43 PM
CLE34014D203
Thanks John. Have a nice holiday!
Strip Poker 388 08-30-2008 09:55 AM
3 Attachment(s)
The trailer Is not notched for the steps and there are chips and cracks in the gel at the steps. Should I trim the trailer bunks for relief at the steps? Or was this simply caused by someone driving the boat off the trailer and not floating it off?
I am not familiar with the 34,going off picks and the assumption its like the 38
most that have shore power have the CCharles onboard charger, mine was a 30amp,some were 20-25,the ac panel below the 12v panel,
As what iv seen the wiring harness is prewired for most ascorys,if it has the 110v panel,shorepower plug port carpeted panel by rear port speaker,under the seat should have a switch panel also,
The paint is a off white, its very thin in mine you can see the black fiberglass/kev/carbon thru it,
my Myco doesn't fir the bottom perfect, there places that the pad doesn't touch and over hangs, I guess if these no support to the pad are it not going to support it,Remember the bottom on the 34 is diff from a 38,I have a bunch of trailer picks with the boat on it and with out.
it should have vents on the Front of the hatch unless its a flat hatch style
Strip Poker 388 08-30-2008 10:01 AM
3 Attachment(s)
you can see the over hang and the first set of steped bunks is short, I make sure there none hanging off the back.
I with i could have another Myco built with me helping. Id change a few things:rolleyes:
Strip Poker 388 08-30-2008 10:08 AM
2 Attachment(s)
Mine has never been a bright white,clean looking,yea a repaint would be nice ,but it would turn into a rerig for me
Elite Marine 08-30-2008 07:50 PM
Thanks Strip. Any idea what type of paint they painted the bilge with? Its not Awl Grip.
I do have an circuit panel under the rear seat. Didn see shore power plu though and no panel in the cuddy.
I will fix the gel on the steps, and modify the trailer at least to get the pressure off the steps.
I have a line on 525's that I might buy and sell the 500's. Any thoughts on that?
Strip Poker 388 09-01-2008 10:29 AM
Im not sure on the paint, I dont think its gel coat, is doesent clean up with hull cleaner.You want have shore power then,
Yes I would get the 525 efis,if its not to much more? they have verry good parts in them to start off with a whipple kit:drink:
Elite Marine 09-02-2008 05:32 PM
It would be a 15K upgrade from the 500's. Not sure its worth it.
I see from your pictures that you have some chips out of your steps too Strip.
Strip Poker 388 09-02-2008 10:48 PM
1 Attachment(s)
its from the trailer and couple look like air voids
put alittle more with it and put whipples on it!! You want regret it:ernaehrung004:
