Sink drain
Currently the drain on the sink simply drains into the hull and gets pumped out via the step pump. Has anyone installed a small tank with a pump to keep water out of the hull. I would expect the less water in the hull the better for longevity of the hull.
I woild think even a small gallon sized tank or pail mounted under the sink with a small pump would suffice. |
1 Attachment(s)
Originally Posted by Elite Marine
(Post 2842123)
I would think even a small gallon sized tank or pail mounted under the sink with a small pump would suffice. I think the opening is too small to get a gallon jug out,you could put a drain fitting in the side,I wouldn't want the looks of it though,mine is painted in there pretty good.The pump gets all but a couple ounces out,I usually vac the carpet once a week,the lint from the towels show up on the blue carpet,if it has any water I shop vac it too. :drink: ....oooO............... .....(....)................ ......)../....Oooo..... .....(_/.....(...)........ ...............)../......... ..............(_/......... ........................... ......oooO............... .....(....)................ ......)../....Oooo..... .....(_/.....(....)....... ...............)../........ .............(_/......... ........................... ......oooO............... .....(....)................ ......)../....Oooo..... .....(_/.....(....)............ ...............)../........ ..............(_/......... ................ |
| All times are GMT -5. The time now is 06:00 PM. |
