Originally Posted by Strip Poker 388
(Post 3067611)
Is that the 7.7 by the throttles? I need to put some speaker up there mine are down low and cant get any volume.Your Boat is looking great:drink:
rob:drink: |
Originally Posted by Elite Marine
(Post 3067634)
In post 17, could someone please hole saw the arm rest in the back to install cup holders? I will send them the cup holders - FREE!!!
I am still dont know if there is anything to prevent the saw from cutting the hole!!! ANYONE? |
Galex JL770 ?
Galex,
I am looking to install the JL770 at the throttles, do you know if there is enough depth to mount them. I see you used the 6.5which according the JL website has a mounting depth of 2.74"/69.5mm the JL770 have a mounting depth of 3.15"/80mm. I look up and tried to measure the best I could I think it's going to be close. How do the JL770 sound? I am upgrading the interior and needed them for mock up. I bought the the ones with a seperate tweeter. THANX |
Originally Posted by galex0100
(Post 3067702)
elite you know i had that whole piece out when doing all this work and cant remember how it was built up but i'v wanted to put some cup holders there so let me pull that piece back out and look i might just take you up on your offer
Works for me! |
Originally Posted by dicdik
(Post 3067794)
Galex,
Galex,
Thanx for the info. I guess I'll cut it out for the 6.5s and if I have the room open it up for the 770's. At least I know the 6.5s will fit if there isn't enough room for the 770s. |
Kirk
If your talking about the rear bench arm rest, I drilled and installed cup holders in the area below where the speaker is located. I centered the hole in the blue upholstery. I thought I sent you some pictures. I will try to find them again for you. Steve |
GALEX,
What amps are you running and where are they located? I've got one set of the JL 770 components already that I've been using for mock up. I know that I am gonna have at least 2 sets of JL 770s components and either a third set or a set of the JL 6.5's. What amp do I need to run all 6 speakers? I was looking to stay with the JL's. |
5 Attachment(s)
(Post 3073322)
GALEX,
What amps are you running and where are they located? I've got one set of the JL 770 components already that I've been using for mock up. I know that I am gonna have at least 2 sets of JL 770s components and either a third set or a set of the JL 6.5's. What amp do I need to run all 6 speakers? I was looking to stay with the Jul's. Rich I have the JUL channel amp for the cabin,4 6 1/2 and a JUL 12 in the birth,I'm very happy the way it came out and its loud,I made a board for the cockpit amps,I need to redo it and ad some more. I know that the speakers close to the floor don't have much volume, Rob:drink: |
Rob,
I was thinking about installling them upside down under the rear bolster when I get it back. Ton of room, lots of air movement and won't be exposed to water unless I got stupid with the hose and spray under the seat. It would be hard to spray water at them by accident. Is there suffient power in the power closet to hook the amps up or do I need to run separate lines? If I mount them under the middle seat of the bolster my power wires and speaker wires would be only a few feet long as opposed to running power up the side. It would cheaper to by longer RCA's then run heavy gauge power wire and speaker wire all over the boat. Just a thought. |
| All times are GMT -5. The time now is 06:04 AM. |
