575SCI's loading up
The port engine on the Slingshot is running very rich. It loads up a little at idle but recently is acting up at higher RPM's (3,500).
I had the plugs, cap, rotor, fuel pump all replaced. The fuel fan from the injector into the motor seems fine. Computer problem on ECU? Any suggestions? Thanks, Chris |
| All times are GMT -5. The time now is 07:11 AM. |
