-   Hustler (https://www.offshoreonly.com/forums/hustler-38/)
-   -   Prop options for a 32 sport? (https://www.offshoreonly.com/forums/hustler/251297-prop-options-32-sport.html)
ballon78 04-12-2011 07:49 PM
96 32 sport, stock 502efi's, has 27's 3 blade mirage's, just bought boat and was wondering what peopl are running with same power...
ive always run 4 blade bravo 1 props on all my boats, but there were all single engines with low x dimentions....
I was thinking a set of 26 bravo ones????
bor 04-13-2011 12:52 PM
Most I saw had bravo's on them ,I run 34 bravo's or 32 maximus but that's on a diesel powered one .
ballon78 04-13-2011 05:39 PM
ya looking for someone with 502 efi's or hp500's stock and then id go one prop size down....
jiffy292 04-15-2011 09:53 AM
i used 19p 3 blades on mine ran 123.4gps
kilrbusa 04-17-2011 01:15 PM
i would think you be closer to 28's 4 blades...those 3 blades dont do anything for me. i have 34's on mine w all the steps
ballon78 04-17-2011 04:49 PM
i thought that if it runs god rpm's with 27 three blades then when you go to a four blade you have to go down a pitch....
Sick Stinger 04-18-2011 12:46 PM
Ballon. I had a 90 32 with 24 hydros. running 550 h.p. @ 5800 ran 81. Like to do the bouce though with 3 and 4 blades had to trim the tabs to keep it level. I had a few pics and vids around here
-Mike
cloneman315 04-20-2011 09:18 PM
Try the Hydros
ballon78 04-22-2011 02:28 AM
i guess no body has stock power still!!!! looking for a baseline befor i go spending 1000 plus on a set of 4 blades....B1's 26's is what i was thinking or hydros 26's....
what are guys with hp500 running for 4 blades??
ballon78 05-15-2011 09:55 AM
Ran with 27 mirages and ran76gps, was very slow, and would blow props out if your wernt very carful. i had to run tab down just to get out. remember this id my first twin so this is all new to me......
yesterday i slaped a set of bravo 1 26p on and its 300% beter , no tabs geting up on plane, it jump out of water with little throthles. ran 78gps but hit rev limiter at 5300 a few times, i had it trimed to 5-6 an tabs at 1.
Do you think i can push the 28's B1's or i also have a set of hydromotive 26's that i have access to to try...
