-   Hustler (https://www.offshoreonly.com/forums/hustler-38/)
-   -   Hustler 388 (https://www.offshoreonly.com/forums/hustler/317757-hustler-388-a.html)
soundwave 09-08-2014 02:14 PM
Hustler 388
Looking at buying the new hustler 388 that was lissted for 60, 000 the 1999 green one. Does anyone knowthe boat or have any info on the condition engines etc thanks
4bus 09-08-2014 02:22 PM
I know the boat very well. Clean, kept indoors, what do you need to know? Owner has purchased another boat and is blowing this one out so he doesn't have to deal with it over the winter.
It also comes with a much better trailer than what you see in the pictures.
soundwave 09-08-2014 02:40 PM
I was at buffalo poker run saw the boat there how are the engines running
4bus 09-08-2014 03:59 PM
He had a loose wire on the primary side of the ignition that has since been fixed. Give him a call, he is easy to talk to.
82predictor 09-08-2014 04:34 PM
I looked at this one before I bought mine. PM i'll give you some info or call the guy, as Ron said the guy is super nice, its stored inside a large garage/pole barn when not in use. HP 500's that have been changed to carb I believe and are almost 600hp. That is cheap money for this kind of boat. I only know of one other that can be bought for that $$$ and its a '97 with 500s.
jeff32 09-08-2014 04:47 PM
Been watching this boat for couple years also!
Just can't make up my mind to green!
But it is a nice boat!
4bus 09-08-2014 05:36 PM
The green IMO looks a lot better in person, and is different. Me, I can't get over the two weld grain dash panels.....which could and should be easily painted over or wrapped :D
Overall the boat is well above average condition, and he still has all the stock 500 efi stuff is someone wanted to convert it back.
soundwave 09-08-2014 07:06 PM
Thanks a lot guys for the info
82predictor 09-08-2014 09:34 PM
A carbon fiber wrap on those two "wood grain" panels would do wonders for the boat. Like I said for 59k it is a heck of a boat. A few thousand to update and repair a few minor things (none of which need to be done to use the boat) and the boat would be mint.
Drock78 09-09-2014 06:36 AM
Green and wood grain dash? We need pics!
