-   Hustler (https://www.offshoreonly.com/forums/hustler-38/)
-   -   Looking for A/C for a 388 Hustler (https://www.offshoreonly.com/forums/hustler/339474-looking-c-388-hustler.html)
GNJ 07-20-2016 07:08 PM
My boat originally came with A/C but the previous owner took the unit out and I never got it. Anybody know what size BTU unit these boats came with and who was the manufacturer?
Anybody not using theirs and wanna sell? Thanks
315duramax 08-01-2016 11:18 PM
i would be interested too.
mikebrls 08-02-2016 08:24 AM
I would think something in the 6000 to 8000 BTU rating would be fine , and you could probably use a Honda 2000 generator to run when not hooked up to shore power
Strip Poker 388 08-02-2016 01:17 PM
does it have the thru hull fitting in front of the step for the water to circulate?
I have used the coleman hatch ac before,maybe 5000btu, it helped during the day and was cool at night.
I know my buddy with a 25 searay w/ 7500btu, my coleman 1850 gen would not start it up,
theres been a few threads on here about putting ac in boats,might search and find some info,
Goodluck
Rob
t500hps 08-02-2016 02:29 PM
I had a Formula 382 with a 7000 BTU Cruiseair unit and we regularly ran it off a Honda 2000. 7000 was enough when it was low 90's during the day and plenty for low 70's at night. A 388 would likely need to same size unit.
GNJ 08-02-2016 08:23 PM
I took a 5000 btu window unit and stuck it in the doorway with cardboard surrounding it to block It was 90* outside and after about 15 mins, the temp inside the cabin dropped to 65*.
GNJ 08-02-2016 08:27 PM
Goodluck
Rob
Yes it does have the through hull fitting and a shut off valve. All the wiring and plumbing is still there, even the temp controller.
315duramax 08-06-2016 07:41 PM
thats ghetto rigged if I've ever heard it lol
GNJ 08-06-2016 10:47 PM
Just did it to test - a little red neck engineering, but proved the size.
Pwraddr 09-17-2016 07:11 AM
5k won't be enough. Need 7-9k. I'd prefer the higher end.
