Does a lay up mean your not completely covered?!?! No!
Obviously, in my field of work, I talk to a lot of boat owners throughout the course of the day. Some calling for advice and others calling to get quotes or bind their insurance coverage.
There is one aspect of the policy that comes up in nearly every quote I give or advice giving conversation that I have and that is the lay up. Often times boat owners assume that having a lay up on your policy means that you are not covered at all during that period of time. This is only partially true. Allow me to explain... If a lay up period is listed on a declarations page then the carrier assumes that the boat is not being used on the water during this period of time. These dates typically coincide with the boater's "winter dates". During the lay up period the boat would be covered for all storage and transit exposures according to the policy form but NOT for any on water use. So just because your season is over and your insurance policy enters it's lay up period, does not mean your not covered for damage to the boat. Some boaters think, that they can cancel an insurance policy because it is "safe" in their storage location during that period of time. Do not make this assumption. I have seen plenty of winter claims comes in for various reasons. Here are some things that happened last year:
Don't assume that your boat is so safely stored during winter that you opt to let your insurance lapse until spring. Keep your policy in force and if you have a lay up on your policy, just don't put the boat in the water. |
I forgot to add something to the above....
Not all policies have designated lay up dates on the declarations page. Most of the carriers that write high performance boats will have a lay up. I think one of the only exceptions to the high performance carriers at this time is American Modern. They do not designate lay up periods on their policies. Lay up policies "credit" a portion of your policy to some degree for not using the boat on the water during your lay up period. So having a lay up period on your performance policy will likely lower the rate. However, if your carrier doesn't do a designated lay up period, don't think that you're not getting any credit. You likely are. Your lay up discount is factored into the rate you pay per $100 in coverage on your boat. For example, the rates paid per $100 in coverage for a MI based policy where you're lucky to have 5 months to boat vs an AZ based policy where you could technically boat year round is less money per $100 in coverage. So the "assumed" lay up time is already factored into your rate. Hope that makes sense. If you need clarification or have questions about lay up periods, let me know. I'll be happy to answer. |
Stacy - curiosity here but let's just say you have a client with layup 11/1 through 5/1 and there is an abnormally beautiful Virginia April Day that this hypothetical client wants to drop it in, what is the process for doing so (if there is one)?
Eric |
Originally Posted by seafordguy
(Post 3376160)
Eric |
Originally Posted by WakezoneINS
(Post 3376504)
The carriers we work with charge about a $100 for a weekend.
(Post 3376504)
Originally Posted by Panther
(Post 3377751)
Hi Stacy, would the same be true if you wanted to take your boat to Florida for a weekend in the winter or do a poker run during the lay-up?
For the most part, yes, same procedure, same concept. However, the additional charge is a little different because the $100 charge is to lift the lay up within your existing policy navigational territory. If your policy territory isn't defined to include Gulf or Coastal Waters of Florida, then you would be endorsing for two different things. Typically, when our clients who are in the Northeast take their boats to Florida for a poker run during their lay up time, their paying around $250 for the week. Granted, that is average. If you have a very high value vessel, then that rate could be a little more. If you are someone who takes their boat down to Florida multiple times during the winter, then it is important to discuss that with your agent. There are policies out there that have year round use allowance and include navigation throughout the entire US up to 150 miles offshore but that are rated based on your main mooring state so you don't pay more for that ability to use the boat in the winter. Endorsement charges can add up so it's good to talk about winter trips with your agent. |
Good info, thanks Stacy
Would it usually be a problem to shift your layup period around? Say the layup is from Sept. 1st to April 1st and you wanted to change it to Oct. 1st to May 1st? Great info!
Originally Posted by fireboatpilot
(Post 3401195)
Changing dates though for even time is something that can be done in a matter of an email or phone call with no hassles. |
| All times are GMT -5. The time now is 02:35 AM. |
