-   LaveyCraft (https://www.offshoreonly.com/forums/laveycraft-205/)
-   -   Interior Picts (https://www.offshoreonly.com/forums/laveycraft/221562-interior-picts.html)
twistedvelocity 01-02-2010 11:39 AM
Would they be best to talk to or would regal?
Uncle Dave 01-02-2010 02:29 PM
Sorry- Regal, I keep thinking you have a velocity. (your name)
UD
twistedvelocity 01-02-2010 02:53 PM
I dont know what to call it really its designed by velocity. but from 87-89 regal owned the velocity name and made them
twistedvelocity 01-03-2010 10:26 PM
What do you think about hitting the 100mph mark?
Uncle Dave 01-03-2010 10:37 PM
thats a nice place to be -I got there before on nitrous.
100hp plate on the 406.
Ive only got 6% slip. Pretty efficient hull.
UD
twistedvelocity 01-04-2010 01:09 AM
Was it scary in that small boat going that fast.
I don't 100% understand the prop slip thing.
Basically like a 6% traction loss yes?
can you get props with no slip?
What prop were you running on that boat?
twistedvelocity 01-04-2010 01:12 AM
Also where do you find is the best place to buy boat parts from?
Uncle Dave 01-04-2010 11:20 AM
The Sebring was not scary, its a solid handler at all speeds and feels planted. It is lite in the front but not like an STV or small outboard tunnell hull/cat I could have kited it by overtrimming.
Your propellers thrust isnt 100% 1-1 the hull and the prop and many factors contribute to "slippage" a transaction loss is a good way to describe it.
You will always have some slip- more blades and bigger diameters help this, but some slip is beneficial to acceleration and drive lifespan.
I was running a hydromotive 4 blade 27 6300RPM.
http://www.go-fast.com/Prop_Slip_Calculator.htm
UD
Uncle Dave 01-04-2010 11:22 AM
Depends on the parts. If Im having them put in for me I always get a square deal from Lavey.
On my own I use CP, Teague, Rex, and Imco, Dana- depends on the part.
Dave
twistedvelocity 01-04-2010 01:37 PM
I gunna open up the bottom end on my stock 350 mag just to check the bearings out and everything. I got a set of roller tipped rockers around here somewhere I was thinking of throwing on for the hell of it. I was also thinking maybe take the heads apart and do alittle porting mainly just remove casting defects. What do you think?
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
