wood in boat
can anyone tell me if there is wood in all laveys or what year they stopped using wood
Not sure but my '99 has a wooden floor.
Most Lavey's have wood. I'm not exactly sure the type of wood off hand, but it isn't the average plywood.
Wood is good
There is wood in my Lavey. Along with carbon fiber and Kevlar. Wood is a predictable substrate and the different types of marine wood products has been refined to the nth degree.
There is truly no substitute for wood when the wood is properly encapsulated and used for the proper reasons. If you determine to use absolutely no wood you give up a light rigid proven product. The substitute construction options have their own set of issues. The process Lavey uses is right on. Wood is superior in the right circumstances in the right hands. Quent |
Originally Posted by cig20
(Post 3548860)
Would you call balsa used as a core material "wood" ? UD |
quents reply x2
there is nothing average about marine grade plywood .best wood grain veneers, no patches, special water resistant glues ,and more
compare the price to an average sheet and you will understand why unfortunately......... many manufacturers use inferior grade materials and pass them off as marine grade there is no escaping better materials cost more |
| All times are GMT -5. The time now is 10:41 AM. |
