Go Back  Offshoreonly.com > Owners Forum > LaveyCraft
GPS transducer for steeped hull >
Old 02-09-2020, 05:55 PM
Default GPS transducer for steeped hull
I have a 2004 29 NuEra 525 efi and the depth finder does not work at any speed past idle. I am installing a Garmin 94sv plus and I am wondering if I will be able to use it while on plane and which transducer will work with the stepped hull.
troyc565 is offline
Old 05-11-2020, 02:35 PM
I'm about to install a depth sounder on my 29 as well. Everything I have read is it needs to be a transom mount transducer in order to get accurate readings. We tried two different in hull (no cutting) models and neither would read.
EBT531 is offline
