-   Magnum Marine (https://www.offshoreonly.com/forums/magnum-marine-63/)
-   -   rebuilding (https://www.offshoreonly.com/forums/magnum-marine/120626-rebuilding.html)
thedonz 03-20-2006 11:25 PM
Re: rebuilding
if your putting her back together to her original look i have the life line for that boat in great shape
jr mike
Smarty 03-21-2006 11:46 AM
Re: rebuilding
Originally Posted by 27 MAGNUM
Did the measuring this weekend, how does 3 inches high sound? Top of Bravo drive ia about 2" below the rub rail curve.
Does that equal 18" or 19" from the bottom of the boat where the outdrive is located to the centerline (the crankshaft). If you go with 19" inches or more you will have to go with four, if not five blade props. There are guys on this forum who have done this conversion, but if I were doing it, it would be primarily for speed, I would do 19". If you are not out for that every last bit of speed, 18" or 18.5" maybe your better choice. Get the cut-out template from Mercury.
27 MAGNUM 03-21-2006 02:45 PM
Re: rebuilding
2 Attachment(s)
The race is on
Smarty 03-21-2006 02:51 PM
Re: rebuilding
The race is on
Looks good!!!
thedonz 03-21-2006 04:40 PM
Re: rebuilding
awsome keeps us posted
jr mike
