150? I'm thinking 40 per engine and 20 per drive.
And you'd want more power than 480s. I think you'd be closer to $250 by the time you're done. Many here come up w/ an original number, and usually end up sometimes double that guesstimate. Now that would make for an interesting thread in the GD. Estimates vs Acutal to get'r done. :) |
(Post 2592489)
And you'd want more power than 480s. I think you'd be closer to $250 by the time you're done. Many here come up w/ an original number, and usually end up sometimes double that guesstimate. Now that would make for an interesting thread in the GD. Estimates vs Acutal to get'r done. :) I prefare a good strong all sea boat, and in the end the Magnum hull is made for max 50-60 knots after that you will have a lot of drag due to the forward deep section which has about 40 50 degrees to my knowledge |
what happened for this project
would be nice to see what have been done for this 38 |
Magnum 35
I purchased a '75 MAGNUM 35 in '95 , in upstate N.Y.,talked w/ Everett Sutton. MAGNUM G.M. at the time, last 35 built!! Boat had twin 400 H.P. Cyclone's, best speed was 39.7 GPS, boat would run in any sea condition, cruised at 28-30 burning 35gph. Sold it in 2000, for another 27' SEDAN w/ 300 h.p. o/b. 35' HIN 351550874........."HIGH LIFE"
Magnum 35
Forgot to add that after a couple of years I called MAGNUM and talked with their engineer about installing diesels. App. cost to replace V-drives and running gear would be $68,000, for a boat that a payed $32,000 for !!! Can buy alot of gas for $36K. HIGH LIFE
1 Attachment(s)
The tab on the 43' Cary is at 45k and climbing...:lolhit: Big boats aren't CHEAP..:daz:
| All times are GMT -5. The time now is 12:33 PM. |
