Cost of new headliner
Have to put in headliners in our Maltese,they will be using the white fuzzy fabric.Everything has been prepped and ready to go we have two to do...what do you think is should cost including material.Also will cover the inside cabin port and starboard panels as you enter the cabin which is flat and should be easy to install...Bud
Bud,did the the one in Vixen last fall,one piece of headliner 10x10 an glue cost me $100.This was the same mat.used in the fountans and bajas,not the fuzzy stuff. Mel
New headliner
Mel the problem with the Maltese is it does not have a flat ceiling,it has some curves to it,making it more difficult to install.Is the material you used the perforated or vinyl type.
Also any one who had it done professionally knowing the cost would be interesting ...thanks Bud |
Originally Posted by Mag27
(Post 2879291)
show-n-go,I don't know the name of the glue because the shop buys it in 5gal. cans and he just gave me a qrt. in a bottle an i didn't see the name.
Bud, if you weren't so far along i'd send you a sample of this stuff,its as light as a feather an very easy to work with.Halli seen it last winter an thought it looked great.
Headliner
According to my installer in IL., if it has foam on the back it will pull away in time.He says most of his current repairs are on foam backed ones.
Also the 29-9 Magnum is down at Rogers in Naples if you are anyone wants to look at it. Bud |
Sorry Bud I thought you were doing it yourself.I did look at the 29, twice,even took some pics of it. Mel
29-9
What do you think...have located the original owner and he is gathering pictures of it so we can restore it as accurate as possible. Bud
Hey Bud, which one are you restoring? The head liner in my Maltese needs to be updated but I love the Austin Powers blue shag. Have you seen anything like the old stuff?
| All times are GMT -5. The time now is 03:26 AM. |
