-   Magnum Marine (https://www.offshoreonly.com/forums/magnum-marine-63/)
-   -   Rebuild on Maltese engine (https://www.offshoreonly.com/forums/magnum-marine/239818-rebuild-maltese-engine.html)
mr vinyl 09-27-2010 03:03 PM
Well the good news is the port engine was re-done by a pro.We will just clean up the seats and put eaknol valves on the exhaust side.
The starboard side was put together by real amateurs,incorrect lifter springs,regular steel valves,damage piston walls, wrong size crank bearings and more sludge in the oil pan than you could imagine.
Dave the engine builder had a good block available,30 over,will need to replace two pistons.correct valves and springs,clean up the heads,crank and bearings,new bearings and total seal rings. I will send pictures on the re-build as I get them. Bud
