-   Magnum Marine (https://www.offshoreonly.com/forums/magnum-marine-63/)
-   -   Clamshell not flush. (https://www.offshoreonly.com/forums/magnum-marine/262128-clamshell-not-flush.html)
scippy 09-11-2011 05:19 PM
2 Attachment(s)
When I purchased my 27 sport it had no deck hardware. I'm about to chrome a set of clamshell vents that I saved from my 18 Donzi & planned to use on the sport. They appear to be the same look & size right down to the matching screw holes.......the only problem is, the deck is curved (back there) which makes the base of the vent not seat well to the surface of the deck.........(see pictures)
Can any other Sport owner verify how their 2 rear clamshell vents sit?....................Just wondering if Magnum made a special rear vent to acccomodate this curvature.
CIG3 09-12-2011 08:19 AM
Check it on a flat surface to make sure it is not warped. I would assume Magnum caulked it in to make up the differance after tweaking it a little.
olredalert 09-12-2011 09:06 AM
-----If there was a difference between the Donzi and the Magnum, the difference wouldnt have been done at Magnum but at the original manufacturer. Algonac Cast Products made those scoops and Magnum may have given ACP a different curvature for the bottom edge. The scoops came from ACP already chromed and certainly wouldnt have been modified at Magnum after delivery.......Bill S
mr vinyl 09-12-2011 09:23 AM
Clam Shells
1 Attachment(s)
I put your clam shell flat against the one I pulled off of my Magnum and they are exactly the same...no curvature. Bud
Bigbroadjumper 09-12-2011 12:50 PM
Bud,
Who did your bolsters?
mr vinyl 09-12-2011 01:37 PM
Bolsters
Bob,they were from the race boat...I have two upholsters on the east coast,one in Ft Lauderdale,and the other in South Miami. I will send you there info. Bud
h2oboater 09-13-2011 01:17 PM
3 Attachment(s)
Here is my 1973 sports vent. It seems to fit flush to the hull.
scippy 09-13-2011 09:20 PM
Mark,
It seems really odd to me that both sides of my rear deck sloop this way & would not accept a level square base .i.e, clamshell vents.......but thanks for verifying by way of pictures.
One more for ya,........have you ever seen a sport with 4 lifeline stanchions?............Mine have 4 evenly spaced screw hole patterns where the lifeline poles would be (between the bow and windshield) ..........I'm starting to think I have a real wacky deck here !!
h2oboater 09-14-2011 02:37 PM
5 Attachment(s)
Originally Posted by scippy (Post 3502906)
Mark,
Never saw a sport with 4 stanchions, I looked at all my pic's that I have.?? Now for the vent I took mine off. If you move it just off from were it was it will rock, see pic. :eek: There must be a slight curve to the deck at any other spot. I compared it to my Donzi doral looks the same but my Magnums were made by Savill Marine Fla ???? The Donzi just says Donzi most likely made here in Mi by Algonac casting like Bill said.
mr vinyl 09-14-2011 06:40 PM
Various Makers of Parts
Mark,I have one set that was made by Savil Marine Haliea Fl..the other was made in Michigan who made items for Chris Craft,Donzi and others.The Magnum clamshell vent is a tad shorter than the Donzi ones,and doesn't have the inside lip.bUD
