Parts Desired
2 Attachment(s)
Hey guys,
Looking for a couple of oddball parts for Maltese restoration. 1). Zurn Bilge pump switch. 3 way auto/On/Off Cant seem to find new (this is the original manufacturer 1974) 2). Bubble hatch 3) Stow away All around navigation light (actually need just the tubing w/electrics) I've added some attachments of the parts indicated above. Thanks again, Jeff |
Parts
I will check if I have an old bilge switch,bubble vent impossible to find unless some one is selling one,can't see the the mast light,it does not increase in size...what are you missing.Also have a sent of less expensive re-chromed some imperfections hatch hinges.
There was a teak option,for the Magnum. Bud |
Originally Posted by mr vinyl
(Post 3554238)
There was a teak option,for the Magnum. Bud http://www.offshoreonly.com/forums/m...atch-vent.html |
Mast light
Thansk Bud, really just need the tube with the electronics inside on the mast light. Aprrox. 22" in total height. It is two peices.
Tried to get the stainless chromed on this old one (it is pitted quite a bit) but the plater was afraid of ruining the connectors inside, they are press fit pin type. Thanks for looking on the bilge switch as well. Please keep me posted. I will send you an e-mail shortly with the mast light so you can zoom in. Jeff |
Mast Light
Jeff go to Radio Shack and buy new pins,re-make the electrical portion of thr mast,add a new SS pole and you are done. Bud
Perko makes a light with the same top section to this day, and as I recall the parts are also available . . I rebuilt the same assembly for my Corsican with these parts 2-3 years ago.
| All times are GMT -5. The time now is 10:37 AM. |
