-   Magnum Marine (https://www.offshoreonly.com/forums/magnum-marine-63/)
-   -   Lead under the bow (https://www.offshoreonly.com/forums/magnum-marine/338217-lead-under-bow.html)
giocariello@gmai 06-12-2016 03:37 AM
Lead under the bow
4 Attachment(s)
I can say that I have finally solved an old problem I had on my Starfire
I installed with a simple but efficient assembly lead that you can see in the attached pics
hallj 06-13-2016 06:54 PM
Gio,
Have you tried 4 blade props?
Will you be in Viareggio for the big show?
Jeff
giocariello@gmai 06-14-2016 01:31 AM
Originally Posted by hallj (Post 4449263)
Gio,
Jeff
Never tried but i have to do it,although i think i'm not as fast as with three
I'm planning to go to Viareggio but without boat
Hope to see you there
bigboat28 06-14-2016 11:55 AM
How many lbs of lead did you put up in the bow?
hallj 06-14-2016 12:16 PM
I'm guessing Gio works in Kilograms.
Jeff
giocariello@gmai 06-14-2016 06:09 PM
I put 300 lbs,as about 140 kg,enough to balance add big block weigh
hallj 06-14-2016 09:51 PM
Have you talked to Giancarlo?
Has he found a new boat yet?
Jeff
giocariello@gmai 06-15-2016 01:22 AM
Jeff
I haven't spoken with him about the 27 but he's still looking for
MDonziM 06-16-2016 06:38 AM
Wow! 300lbs?! That seems like a lot of weight to me, how far forward is it. I hope that wood base is fiberglassed in well to hold that weight.
giocariello@gmai 06-16-2016 07:54 AM
My Starfire came with two fuel tanks only and miss weight under bow than others
