Core material in Maltese
anyone ever recore a Maltese? if so, I'm curious to know what the core material is when Magnum Marine first built the Maltese Thanks in advance for any info . |
If you are talking about the transom core, Magnum used mahogany plywood. The decks were cored with balsa.
thanks 70, good info now I just need info on the core of the hull . |
Originally Posted by noli
(Post 4646067)
That is correct. The hulls are single skinned, no core. The stringers are the only other component in the hull construction and they consist of marine grade plywood.
Thank you, very good info! how thick is the skin? . |
It varies depending on the area of the hull. High stress areas have more layers of fiberglass roving. The thinnest areas are probably at the upper part of the hull near deck-hull joint. That area on my old Magnum Sedan was about 3/8 to 1/2 inch thick.
| All times are GMT -5. The time now is 02:07 AM. |
