-   Magnum Marine (https://www.offshoreonly.com/forums/magnum-marine-63/)
-   -   28 maltese help (https://www.offshoreonly.com/forums/magnum-marine/87471-28-maltese-help.html)
Stormrider 09-23-2004 06:53 AM
28 maltese help
Freind of mine is going to look at a 1976 28. It is still owned by the original owners.
It will need some major refreshening and updating.
1. When he goes to look at it, are there any specific things he should look for? any weak points?
2. Does anyone have any pictures of the 28s that have been updated? so he can get some ideas?
Thanks for the help.
magnum27 09-23-2004 08:35 AM
Re: 28 maltese help
There is a 28 for sale that has been updated on the Boat trader, nothing unusual to look for. Check stringers, bulkheads and transom for soft spots.
Stormrider 09-24-2004 08:02 AM
Re: 28 maltese help
What is the weight of a 28?
magnum27 09-24-2004 08:31 AM
Re: 28 maltese help
Just and educated guess but I would say around 6500 lbs.
Stormrider 09-24-2004 09:26 AM
Re: 28 maltese help
Owner said 5000... sounds a bit light to me.
Is there a place where I could see a an origianl write up or brochure on this boat?
magnum27 09-24-2004 12:23 PM
Re: 28 maltese help
With twin engines there is NO way it weighs 5000 pounds. A single engine big block in a 27 will still weigh more than 5000 pounds. You need to contact Evertt Sutton at Magnum. He will be able to send you all kinds of info and brochures on the boat. If you have the vin # he might even be able to tell you some history on it. They have a huge filing cabinet full of info on the magnums. He is a great guy to talk to. His number is (305) 931-4292.
bigd1 09-30-2004 09:16 PM
Re: 28 maltese help
I posted an ad I picked up on e-bay over on speedwake. Look under the dock area under magnums.
magnuman 10-01-2004 02:06 PM
Re: 28 maltese help
Weight with twin small blocks is 6500 lbs,
jsmagnum 01-29-2005 11:03 AM
Re: 28 maltese help
Im having trouble with paypal taking my credit card.
Until then I cant start any posts.
I need to know what the x dimension should be on a single engine 28 ft magnum
tripps 02-13-2005 05:53 PM
Re: 28 maltese help
I dontknow how to measure and set the x but that gearcase better be at least 4 inches below the bottom,cause i did one with the centerline of the propshaft even with the bottom and the prop 48 inches from the transom,the hull would lift in the front,it was a sedan,a little heavier in the front,itwent 70 with 680 horsepower at 5700 rpm with a sternpower speedmaster outdrive and bw 72 tranny. there were no front lift props for that drive,which took speedy 3 props. i was alittle dissapointed in the performance after all the work i did converting from twins to a single,so itook it apart,bought a 30 velocity with tripple mercs and have alot of fun with it!!! good luck tripps
MrCIG 02-15-2005 07:06 PM
Re: 28 maltese help
1 Attachment(s)
Here is a picture of an old 28 that a guy in the a Chicago area owns. The boat is beautiful. He owns a powdercoating company so everything is powdercoated.
Stormrider 02-16-2005 08:12 AM
Re: 28 maltese help
Mr Cig, can you get me more pics of that boat?
el indio 03-21-2005 08:41 PM
Re: 28 maltese help
1 Attachment(s)
m.m.
Stormrider 06-19-2005 07:21 PM
Re: 28 maltese help
I saw the boat this weekend.
My friend completey stripped it down.
Repainted, new teak cockpit sole, new interior, lights, popup cleats, new dash/wheel/shifters/compass...
The only thing he didnt change was the engine/drivetrain.
The thing looks sweet so far!!!
He says it will be in the water July!
I will post pics when he is done.
