Go Back  Offshoreonly.com > Owners Forum > Motion
fuel tanks in a Motion... >
Old 04-11-2008, 05:23 PM
Default fuel tanks in a Motion...
Wondered if the fuel tanks in a Motion are glass or aluminum.Any trouble with the ethanol blend fuel??
dozer1 is offline
Old 04-12-2008, 06:54 AM
Motion tanks are fiberglass. Some are having problems, and others have not. Easiest way to check is to remove the fuel filter and cut it apart. There will be goal/amber chips in the bottom of the fuel filter.
To fix this problem you have to cut the top of the tank off and cover the tank with a two part expoxy.
hope this helps.
Maritime_Eng is offline
Old 05-27-2008, 04:22 PM
Mine are aluminum 1994 25'
skydog is offline
Old 03-11-2009, 04:01 PM
Thumbs up
My tanks are aluminum also 91 25.0
joe rockhead is offline
Old 03-11-2009, 04:12 PM
my are aluminum......
lowblue320 is offline
Old 03-11-2009, 05:23 PM
You are all very lucky. My last two 30 Motions have both been Fiberglass and I had to redo them both.......
Old 03-11-2009, 05:43 PM
OL40SVX's Avatar
It depends on year and what model boat.
OL40SVX is offline
Old 05-09-2010, 10:24 PM
How big of a task was it to repair the tanks? I'm looking at a boat that might have the same problem...
FullAuto9 is offline
Old 05-10-2010, 05:19 AM
It was a big pain in the ass. Lots of work if you do it yourself.
Old 05-10-2010, 08:14 AM
CcanDo's Avatar
We replaced our Aluminum tanks.....New tanks are 5053 H36, 3/16" material (not 1/8" or .125 ) though the thicker material has a greater wt. factor it also has more rigidity....The extra rigidity may reduce work hardening, thereby effecting porosity.
Regardless of materials used (fiberglass, Aluminum or stainless ) IMHO it may be appropriate to consider DUAL vents, a water trap and two flapper valves for the purpose of slowing if not eliminating ambient air when fuel is not being drawn. Further, as fuel is being drawn the water trap is TO collect moisture, without restriction.
Subject to plumbing design, the system should breath without positive or negative tank pressure.
CcanDo is offline
Quick Reply: fuel tanks in a Motion...
