how fast 30 with 225's
just got my new to me 30 with 225's.only pulled 78 on gps.thought it would be alittle faster.am i missing something.this is my 1st boat with twin outboards.it was very calm on the lake.should it run faster with some chop?thought it would run 83-85
Originally Posted by awsomethunder
(Post 2606508)
You might want to measure your X dimension and see where you are at. It the motors are too low in the water that will also slow you down. Hope this helps Don |
don should i be turning my props in or out.it seems alot of cats are turning out.where should my x dimension be?
(Post 2607676)
The X dimension should be 1.5 to 1.75 above the running surface. What props do you have on the boat? How much fuel were you carring? How many people were with you? |
15x30 labbed cleavers,1/2 tank each side,1 passenger,hot and humid.
(Post 2607817)
about 6500
Thats 11% slip.. I'm not sure whats a normal slip ratio on a cat. I know I have mine down to 9% now and I'm not sure if I can do better.
what are you spinning for props?
15X25 Hydromotives at 8200/8300 rpm. 83/84mph
| All times are GMT -5. The time now is 08:11 AM. |
