35 xp
Hi guys setting up a 35 XP to race and before we purchase engines we want to double check the weight of the boat. anyone have any idea as to what these things weigh?
thanks |
from there website.
Motion 35XP Be the DOMINATOR!!! Experience the same winning hull that won the 2000 A.P.B.A. Factory-3 National Championship. A true thoroughbred, this model is outfitted with two F-16 canopies for maximum wind deflection and visibility at high speeds. Our spacious cockpit has two front racing style bucket seats with a bolster style rear bench seat for three. We have incorporated a full fiberglass inner liner for superior structural integrity and easy cleaning. This model has been designed for various power options. Specifications Length: 35'0" Beam: 9'3" Weight:3,200 lbs Fuel Capacity: 200 gallons Standard Equipment Custom racing bucket seats with rear bench seat seat with combing pads S/S pop-up cleats (4) S/S lifting eyes, bow and stern s/s fuel fills White color gel coat Hull and deck bonded around entire perimeter Bi-Tri Axial Directional Fiberglass construction using vacuum bag techniques Vinyl-ester resin |
thank you.
Sounds promising! Does anybody know what the fuel tanks are made of ?
Fuel tanks are most likely fiberglass. That could pose a problem with today's fuels. I have owned four Motions and most had tank problems. The fix for me was installing aluminum tanks. Skaters have the same issue.
Skaters HAD the issue, haven't heard of ethanol breakdown since the issue was discovered and Peter made the resin change in the tank construction / older boats had the tanks rebuilt
wich resin they had? and wich one they took to solve the problem ?
| All times are GMT -5. The time now is 02:18 PM. |
