Hatch Actuator Remote
1 Attachment(s)
Innovative thinking brings you this compact hatch actuator remote, specifically designed for hatch lifting. The remote can serve several functions including: opening a hatch from 300 feet away, activating the blower, switching the cabin lights on/off, to name a couple. Can be used on most hatch motors, electric or hydraulic, even on boats using two separate hatches. The receiver module can be mounted under the dash, wired to the hatch switch or wired directly to the motor. But don’t worry the manual switch is still usable. The remote fits right on your keychain! No worries if you accidentally drop your keys in the water, the remote floats!! Or you can use the dash mount. It’s water proof and has a UV resistant remote case. Easy installation gets you back on the water in no time! Each kit comes with one receiver and two remotes. Don’t forget we also offer Hatch Actuators with colored sleeves and private labeling! 10 Livorsi Drive Grayslake, IL 60030 Office: (847)548-5900 Toll Free: (877)548-5900 Fax: (847)548-5903 www.livorsi.com |
| All times are GMT -5. The time now is 04:52 PM. |
