Free Bully Dog Mag Lite...
1 Attachment(s)
...with any Bully Dog purchase, while supplies last... :D
http://www.bullydog.com/images/home-page.gif |
Re: Free Bully Dog Mag Lite...
Bully Dog's Triple Dog Combo Kit # 41500 will program all Ford 6.0's, 06-07 GM Duramax, & 06-07 Dodge Cummins.
http://www.tpmarine.com/ProductImage...og/bd41500.jpg Bully Dog Triple Dog Power Pup w/Outlook Monitor - Ford 6.0L 03-07 Bully Dog Triple Dog Power Pup w/Outlook Monitor Dodge Cummins - 06-07 Bully Dog Triple Dog Power Pup w/Outlook Monitor Dodge Cummins - 03-05 Bully Dog Triple Dog Power Pup w/Outlook Monitor - Duramax 06-07 Bully Dog Triple Dog Power Pup w/Outlook Monitor - Duramax 01-05 |
Bully Dog Triple Dog Power Pup Programmer Only
This programmer will program the Ford 6.0, Dodge Cummins, & GM Duramax. The Triple Dog works on the following trucks: Dodge Cummins 03 to 06 Ford Powerstroke 6.0L 03 to 07 GM Duramax 01 to 07 https://2606042413.monstercommercesi.../BD40500sm.jpg |
The Outlook Monitor comes with a bracket for easy mounting, or you can use a pillar pod mount...:)
http://www.tpmarine.com/ProductImage...og/bd31301.jpg Bully Dog Ford-Outlook Pod 6.0L 03-07 Bully Dog Dodge-Outlook Pod 03-07 Bully Dog GM/Chevy-Outlook Pod 99-07 w/speaker Bully Dog GM/Chevy-Outlook Pod 99-07 w/o speaker |
Bully Dog's Rapid Flow Cold Air Induction!
http://www.tpmarine.com/ProductImage...g/bd221102.jpg Bully Dog Ford 6.0L RFI Intake 03-04 & 06-07 Bully Dog Ford 6.0L RFI Intake 05 only Bully Dog Ford 7.3L RFI Intake 99-03 Bully Dog Ford 7.3L RFI Intake 94-98 The Bully Dog RFI is an advanced airflow induction built to increase the engine?s ability to breath. By replacing the restrictive stock induction, RFI increases horsepower, torque, fuel efficiency, and decreases exhaust gas temperatures. By removing the stock air box, replacing it with a metal heat shield, and using a conical air filter you can maximize the air filter cleaning area and allow the engine to breathe easier and produce more horsepower. All RFI inductions use a lifetime reusable 4” layer cotton gauze filter. This design, combined with deep pleats, make these filters ideal for high performance use. This induction also works very well in conjunction with performance computer modules. The modules will increase the amount of fuel going into the motor and will therefore increase the need for more air. The installation of this system is very easy and requires only very basic hand tools. Installation can generally be done in 20 minutes or less. |
Bully Dog RFI ColdAir Induction - Duramax (01-05)
http://www.tpmarine.com/ProductImage...g/bd221102.jpg The Bully Dog RFI is an advanced airflow induction built to increase the engine's ability to breath. By replacing the restrictive stock induction, RFI increases horsepower, torque, fuel efficiency, and decreases exhaust gas temperatures. By removing the stock air box, replacing it with a metal heat shield, and using a conical air filter you can maximize the air filter cleaning area and allow the engine to breathe easier and produce more horsepower. All RFI inductions use a lifetime reusable 4” layer cotton gauze filter. This design, combined with deep pleats, make these filters ideal for high performance use. This induction also works very well in conjunction with performance computer modules. The modules will increase the amount of fuel going into the motor and will therefore increase the need for more air. The installation of this system is very easy and requires only very basic hand tools. Installation can generally be done in 20 minutes or less. Watch Stacy David from Trucks! install a RFI as he turns Diesel Adrenaline into the ultimate towing machine . |
Bully Dog 4" Stainless Steel Exhaust Systems...turbo back & cat back kits available depending on you application.
Bully Dog 4" T-304 SST Exhaust - Ford 7.3L (99-03) Bully Dog 4" T-409 SST Exhaust - Ford 6.0L (03-06) http://www.tpmarine.com/ProductImage...g/bd181446.jpg Bully Dog Technologies Rapid Flow Exhaust Systems are designed and built with absolute minimal degree angles on bends. This will create the most free flowing low back pressure system in the industry allowing the turbo to move air more freely, reducing exhaust temperatures. Dyno results have shown a significant gain in horsepower by simply switching from stock to a Rapid Flow Exhaust System. Available in 16-gauge aluminized, T-304 micro shine stainless steel or T-409 stainless steel The Rapid Flow Exhaust Systems have the lowest degree mandrel bends offering free flowing and low back pressure. This will lower exhaust temperatures by as much as 200 degrees and provides 10-20 hp increases dependent upon size upgrade and current horsepower output. Bully Dog recommends using a 4” exhaust system for horsepower applications less than 450 hp, while the 5” systems are recommended between 450 to 550 horsepower applications, and our new 6” systems are recommended for trucks producing more than 550 hp. |
I only have a few flashlights left...place your order before the holidays and I will throw in the shipping.
FREE SHIPPING for the remainder of the Year!!! :drink: |
| All times are GMT -5. The time now is 12:17 PM. |
