-   New Products and Member Discounts (https://www.offshoreonly.com/forums/new-products-member-discounts-139/)
-   -   Happy Holidays (https://www.offshoreonly.com/forums/new-products-member-discounts/146493-happy-holidays.html)
teaguecustommarine 10-06-2007 11:39 AM
The Only Silicone You Need
3 Attachment(s)
Valco has simplified your purchase decision with one premium-grade RTV silicone that does it all. Now there’s no need to have a complicated assortment of specialized RTV sealants for every engine-sealing job.
Valco’s patented Tube-Grip® greatly improves the handling and dispensing of All-In-One Silicone™ or any material packaged in a flexible tube. The Tube-Grip dispenses material accurately and efficiently. In fact, the Tube-Grip maximizes the usage of all the material in the tube due to its effective means of application.
SILICONE ONLY $4.33 EACH ANY COLOR
SILICONE W/TUBE GRIP $13.76 EACH ANY COLOR
71105 ALL-IN-ONE SILICONE, Clear 3 oz. tube & nozzle
71135 ALL-IN-ONE SILICONE, Black 3 oz. tube & nozzle
71195 ALL-IN-ONE SILICONE, Aluminum 3 oz. tube & nozzle
71106 TUBE-GRIP w/ALL-IN-ONE SILICONE, CLEAR 3 oz. tube
71196 TUBE-GRIP w/ALL-IN-ONE SILICONE, ALUMINUM 3 oz. tube
71136 TUBE-GRIP w/ALL-IN-ONE SILICONE, BLACK 3 oz. tube
teaguecustommarine 10-06-2007 11:55 AM
Prop Locks And Drive Locks
2 Attachment(s)
PROP $459.97
DRIVE $10,000.00
TIME YOU LOOSE ON YOUR
VACATION BECAUSE SOMEONE TOOK
ONE OR THE OTHER OR BOTH $$$$$$$
SOMEONE LOOKING AT THE BACK OF
YOUR BOAT AND SEEING LOCKS SO THEY
MOVE ON $ PRICELESS
Theft protection in and out of the water.
Mcgard is the most trusted name in security
for over 30 years.
PROP LOCKS PART #67-808915 $51.06
DRIVE LOCKS PART #67-808910 $21.77
TRS DRIVE LOCK PART #67-829387 $26.40
teaguecustommarine 10-06-2007 01:23 PM
Washing Supplies
1 Attachment(s)
18" Blade With Ext Pole #20039 $39.99
12" Jelley Blade #20080 $23.84
towel-microfiber 16x24 #22200 $9.95
wash Mitt-microfiber #22012 $7.76
The Original California Heavy Duty Water Blade With 3 Section Telescoping Extension Handle Dries Large Surfaces. The Jelly Blade Ultra Flexible Water Blade Helps To Mold To Shapes And Curves. The Microfiber Wash Mitt Can Be Used As A Wash Mitt When Wet And A Duster When Dry. The Microfiber Clean And Polish Plush Towel Is Perfect For Waxing, Cleaning And Polishing.
Microfiber Id 100 Times Finer Than Human Hair. The Tiny Fibers Have Micro Grooves Which Act To Absorb Fluids.
Microfiber Will Not Scratch Even The Most Delicate Surfaces. Wash And Re-use 100's Of Times!
teaguecustommarine 10-06-2007 01:46 PM
Streamlight LED flashlight
2 Attachment(s)
sSL-20X LED FLASH LIGHT PART#20201 $124.85
Streamlights make an excellent gift for ANYONE who needs a dependable light for work or play. You don't have to be a Policeman or Fireman to appreciate a Streamlight flashlight.The Streamlight SL-20XP™ HALOGEN & LED is a lighter. Almost indestructible case, rechargeable, up to 25,000 candlepower.
Length: 13.2” Weight: 1.1 lbs.
Full-size yet lightweight incandescent/LED rechargeable that combines the brightness of an incandescent with the extended run time of LEDs – the best of both worlds.
teaguecustommarine 10-06-2007 02:04 PM
For The Ladies
1 Attachment(s)
We Know They Love The Bling.
Ladies Tanks And Cap To Match
All Bling All The Time
Matching Tank And Hat $90.00
