Livoris Livorsi Livorsi
Offshoreonly Advertiser
Can you get me a quote on some gauges? it wont let me PM you. Also, does livorsi make a gauge that doesnt have flat glass in it? looking for something bubbled out a little.. if not, i need a full set (2 motors) with regular speedo, 6k tachs, volts, oil pressure, water, single fuel and dual trim. yellow rim, yellow angled and flat bezels for all but tach and speedo. Silver Carbon fiber face.. lookin for something pretty custom so im open for ideas!
[email protected] or on here, thanks!
I will email you a quote with pics
thanks
thanks
Looking to do a twin engine with oil pressure and temp, water temp. and pressure, volts, 1 fuel, tachs, speedo. White faces blue bezels.
[email protected]
[email protected]
white face blue rim or white face white rim with blue bezels?
i will email you
i will email you
[email protected]
[email protected]
These senders provide an accurate, continuous readout of fuel or water levels even in a moving boat. Consisting of a single in-tank probe and an amplifier, it’s innovative technology renders the traditional float arm assembly obsolete.
* No moving parts, nothing to break or wear out
* Prevents pointer bounce
* Can be cut and calibrated in the field
* Available in 12 or 24 volts
* Detect water in fuel
* Other ohm resistances available
* Requires 12 volts
* Standard SAE 5 bolt pattern
* Requires 12 volts
